Wii Remote Bluetooth Connection Problem with Pin-Code
2023-07-16T21:25:27+00:00
I've been trying to connect my Wii Remote (Motionplus inside) to my pc, but it prompts me with a Pin-Code i dont know. When i search for it it usally says i should try 0000 or 1111 but it has never worked, i can't press skip, as there is no skip option. Im so lost on what to do. I've also tried connecting from Devices and Printers, same thing there too.
Summary: Im forced to use a Pin Code. I dont know the Pin Code.
Windows for home | Windows 11 | Enheter og drivere
6 svar
Sorter etter: Mest nyttig
    2023-07-17T18:59:15+00:00
    I did, and the Gerrydoro driver said it had updated it. But when i opened settings it still read out Driver Error, so i opened the bluetooth searching and nothing showed up, i closed it and then it displayed it as connected (see screenshot), i obviously became really happy and suprised until it went back to showing driver error (screenshot), i can repeat this as many times as i want, and it always says connected for around a second before disconnecting.
    Bilde
    (Connected)
    Bilde
    (Driver Error)
    If you need me to send a screen recording i could do that
    Var dette svaret nyttig?
