Wii Remote Bluetooth Connection Problem with Pin-Code
2023-07-16T21:25:27+00:00
I've been trying to connect my Wii Remote (Motionplus inside) to my pc, but it prompts me with a Pin-Code i dont know. When i search for it it usally says i should try 0000 or 1111 but it has never worked, i can't press skip, as there is no skip option. Im so lost on what to do. I've also tried connecting from Devices and Printers, same thing there too.
Summary: Im forced to use a Pin Code. I dont know the Pin Code.
Windows for home | Windows 11 | Enheter og drivere
6 svar
Sorter etter: Nyeste
  1. Rodrigo Queiroz 78,730 Omdømmepoeng Uavhengig rådgiver
    2023-07-16T23:47:34+00:00
    Hi Ed,
    I'm Rodrigo and I'll help you.
    Check if the solution from gerrydoro in the link below works for you.
    https://answers.microsoft.com/en-us/windows/for...
    Var dette svaret nyttig?
