Create a vector index in Azure AI Search
In Azure AI Search, you can store and query vectors in a search index. A vector index is defined by an index schema that has vector fields, nonvector fields, and a vector configuration section.
Creating a vector index implicitly creates an embedding space that serves as the corpus for vector queries. The embedding space consists of all vector fields populated with embeddings from the same embedding model. At query time, the system compares the vector query to the indexed vectors and returns results based on semantic similarity.
This article uses REST to explain how to create a vector index, which includes the following steps:
  • Start with a basic schema definition
  • Add vector algorithms and optional compression
  • Add vector field definitions
  • Load prevectorized data as a separate step or use integrated vectorization to chunk and embed data during indexing
After you understand the basic workflow, try the Azure SDK samples in the azure-search-vector-samples GitHub repo for guidance on using vectors in test and production code. You can also use the Azure portal to create a vector index via integrated vectorization.
Prerequisites
  • An Azure AI Search service in any region and on any tier. If you plan to use integrated vectorization with the Azure Vision skill and vectorizer, Azure AI Search must be in the same region as the embedding models hosted on Azure Vision in Foundry Tools.
  • For the recommended keyless authentication, assign the Search Service Contributor and Search Index Data Contributor roles to your user account, managed identity, or service principal. For the less secure key-based authentication, obtain an admin API key.
  • Source documents with vector embeddings to upload to the index. You can also use integrated vectorization for this task.
  • The dimensions limit of your embedding model. text-embedding-ada-002 is fixed at 1536, text-embedding-3-small ranges from 1 to 1536, and text-embedding-3-large ranges from 1 to 3072.
  • The similarity metric for your embedding model. Azure OpenAI models use cosine.
  • Familiarity with creating an index. A schema always includes a field for the document key, fields for search or filters, and other configurations for behaviors needed during indexing and queries.
Some search services created before January 2019 can't create a vector index. If applicable, create a new service to use vectors.
Prepare documents for indexing
Before indexing, assemble a document payload that includes fields of vector and nonvector data. The document structure must conform to the fields collection of index schema.
Make sure your source documents provide the following content:
Content Description
Unique identifier A field or a metadata property that uniquely identifies each document. All search indexes require a document key. To satisfy document key requirements, a source document must have one field or property uniquely identifies it in the index. If you're indexing blobs, it might be the metadata_storage_path that uniquely identifies each blob. If you're indexing from a database, it might be primary key. This source field must be mapped to an index field of type Edm.String and key=true in the search index.
Non-vector content Provide other fields with human-readable content. Human-readable content is useful for the query response and for hybrid queries that include full-text search or semantic ranking in the same request. If you're using a chat completion model, most models like ChatGPT expect human-readable text and don't accept raw vectors as input.
Vector content A vectorized representation of your nonvector content for use at query time. A vector is an array of single-precision floating point numbers generated by an embedding model. Each vector field contains a model-generated array. There's one embedding per field, where the field is a top-level field (not part of a nested or complex type). For simple integration, we recommend embedding models in Azure OpenAI, such as text-embedding-3 for text documents or the Image Retrieval REST API for images and multimodal embeddings.
If you can use indexers and skillsets, consider integrated vectorization, which encodes images and text during indexing. Your field definitions are for vector fields, but incoming source data can be text or images, which are converted to vector arrays during indexing.
Your search index should include fields and content for all of the query scenarios you want to support. Suppose you want to search or filter over product names, versions, metadata, or addresses. In this case, vector similarity search isn't especially helpful. Keyword search, geo-search, or filters that iterate over verbatim content would be a better choice. A search index that's inclusive of both vector and nonvector fields provides maximum flexibility for query construction and response composition.
For a documents payload example, see the Load vector data for indexing section.
Start with a basic index
Start with a minimum schema so that you have a definition to work with before adding a vector configuration and vector fields. A simple index might look the following example. For more information about an index schema, see Create a search index.
Notice that the index has a required name, a required document key ("key": true), and fields for human-readable content in plain text. It's common to have a human-readable version of whatever content you intend to vectorize. For example, if you have a chunk of text from a PDF file, your index schema should have a field for plain-text chunks and a second field for vectorized chunks.
Here's a basic index with a "name", a "fields" collection, and some other constructs for extra configuration:
POST https://[servicename].search.windows.net/indexes?api-version=[api-version]
  "name": "example-index",
  "description": "This is an example index."
    { "name": "documentId", "type": "Edm.String", "key": true, "retrievable": true, "searchable": true, "filterable": true },
    { "name": "myHumanReadableNameField", "type": "Edm.String", "retrievable": true, "searchable": true, "filterable": false, "sortable": true, "facetable": false },
    { "name": "myHumanReadableContentField", "type": "Edm.String", "retrievable": true, "searchable": true, "filterable": false, "sortable": false, "facetable": false, "analyzer": "en.microsoft" },
  "analyzers": [ ],
  "scoringProfiles": [ ],
  "suggesters": [ ],
  "vectorSearch": [ ]
Add a vector search configuration
Next, add a "vectorSearch" configuration to your schema. It's useful to specify a configuration before field definitions, because the profiles you define here become part of the vector field's definition. In the schema, vector configuration is typically inserted after the fields collection, perhaps after "analyzers", "scoringProfiles", and "suggesters". However, order doesn't matter.
A vector configuration includes:
  • vectorSearch.algorithms used during indexing to create "nearest neighbor" information among the vector nodes.
  • vectorSearch.compressions for scalar or binary quantization, oversampling, and reranking with original vectors.
  • vectorSearch.profiles for specifying multiple combinations of algorithm and compression configurations.
Here are the steps:
  1. Use the Create or Update Index REST API to create the index.
  2. Add a vectorSearch section in the index that specifies the search algorithms used to create the embedding space.
         "compressions": [
                 "name": "scalar-quantization",
                 "kind": "scalarQuantization",
                 "scalarQuantizationParameters": {
                     "quantizedDataType": "int8"
                 "rescoringOptions": {
                     "enableRescoring": true,
                     "defaultOversampling": 10,
                     "rescoreStorageMethod": "preserveOriginals"
                 "name": "binary-quantization",
                 "kind": "binaryQuantization",
                     "rescoreStorageMethod": "discardOriginals"
                 "name": "hnsw-1",
                     "efSearch": 500,
                     "metric": "cosine"
                 "name": "hnsw-2",
                     "m": 8,
                     "efConstruction": 800,
                     "efSearch": 800,
                     "metric": "hamming"
                 "name": "eknn",
                 "kind": "exhaustiveKnn",
                 "exhaustiveKnnParameters": {
                     "metric": "euclidean"
             "name": "vector-profile-hnsw-scalar",
             "compression": "scalar-quantization",
             "algorithm": "hnsw-1"
    Key points:
    • Names for each configuration of compression, algorithm, and profile must be unique for its type within the index.
    • vectorSearch.compressions can be scalarQuantization or binaryQuantization. Scalar quantization compresses float values into narrower data types. Binary quantization converts floats into binary 1-bit values.
    • vectorSearch.compressions.rescoringOptions uses the original, uncompressed vectors to recalculate similarity and rerank the top results returned by the initial search query. The uncompressed vectors exist in the search index even if stored is false. This property is optional. Default is true.
    • vectorSearch.compressions.rescoringOptions.defaultOversampling considers a broader set of potential results to offset the reduction in information from quantization. The formula for potential results consists of the k in the query, with an oversampling multiplier. For example, if the query specifies a k of 5, and oversampling is 20, the query effectively requests 100 documents for use in reranking, using the original uncompressed vector for that purpose. Only the top k reranked results are returned. This property is optional. Default is 4.
    • vectorSearch.compressions.scalarQuantizationParameters.quantizedDataType must be set to int8. This is the only primitive data type supported at this time. This property is optional. Default is int8.
    • vectorSearch.algorithms is either hnsw or exhaustiveKnn. These are the Approximate Nearest Neighbors (ANN) algorithms used to organize vector content during indexing.
    • vectorSearch.algorithms.m is the bi-directional link count. Default is 4. The range is 4 to 10. Lower values should return less noise in the results.
    • vectorSearch.algorithms.efConstruction is the number of nearest neighbors used during indexing. Default is 400. The range is 100 to 1,000.
    • "vectorSearch.algorithms.efSearch is the number of nearest neighbors used during search. Default is 500. The range is 100 to 1,000.
    • vectorSearch.algorithms.metric should be cosine if you're using Azure OpenAI, otherwise use the similarity metric associated with the embedding model you're using. Supported values are cosine, dotProduct, euclidean, and hamming (used for indexing binary data).
    • vectorSearch.profiles add a layer of abstraction for accommodating richer definitions. A profile is defined in vectorSearch and referenced by name in each vector field. It's a combination of compression and algorithm configurations. You assign this property to a vector field, and it determines the fields' algorithm and compression.
Add a vector field to the fields collection
Once you have a vector configuration, you can add a vector field to the fields collection. Recall that the fields collection must include a field for the document key, vector fields, and any other nonvector fields you need for hybrid search scenarios or chat model completion in RAG workloads.
Vector fields are characterized by their data type, a dimensions property based on the embedding model used to output the vectors, and a vector profile that you created in a previous step.
  1. Use the Create or Update Index REST API to create the index and add a vector field to the fields collection.
            "name": "contentVector",
            "type": "Collection(Edm.Single)",
            "searchable": true,
            "retrievable": false,
            "dimensions": 1536,
            "vectorSearchProfile": "vector-profile-1"
  2. Specify a vector field with the following attributes. You can store one generated embedding per field. For each vector field:
    • type must be a vector data type. Collection(Edm.Single) is the most common for embedding models.
    • dimensions is the number of dimensions generated by the embedding model. For text-embedding-ada-002, it's fixed at 1536. For the text-embedding-3 model series, there's a range of values. If you're using integrated vectorization and an embedding skill to generate vectors, make sure this property is set to the same dimensions value used by the embedding skill.
    • vectorSearchProfile is the name of a profile defined elsewhere in the index.
    • searchable must be true.
    • retrievable can be true or false. True returns the raw vectors (1,536 of them) as plain text and consumes storage space. Set to true if you're passing a vector result to a downstream app.
    • stored can be true or false. It determines whether an extra copy of vectors is stored for retrieval. For more information, see Reduce vector size.
    • filterable, facetable, and sortable must be false.
  3. Add filterable nonvector fields to the collection, such as title with filterable set to true, if you want to invoke prefiltering, postfiltering, or strict postfiltering (preview) on the vector query.
  4. Add other fields that define the substance and structure of the textual content you're indexing. At a minimum, you need a document key.
    You should also add fields that are useful in the query or in its response. The following example shows vector fields for title and content (titleVector and contentVector) that are equivalent to vectors. It also provides fields for equivalent textual content (title and content) that are useful for sorting, filtering, and reading in a search result.
    The following example shows the fields collection:
    PUT https://my-search-service.search.windows.net/indexes/my-index?api-version=2026-04-01&allowIndexDowntime=true
    api-key: {{admin-api-key}}
        "name": "{{index-name}}",
                "name": "id",
                "filterable": true
                "name": "title",
                "searchable": true,
                "filterable": true,
                "sortable": true,
                "retrievable": true
                "name": "titleVector",
                "searchable": true,
                "dimensions": 1536,
                "name": "content",
                "searchable": true,
                "retrievable": true
                "searchable": true,
                "dimensions": 1536,
                    "name": "hnsw-1",
                        "efSearch": 500,
                        "metric": "cosine"
                    "name": "vector-profile-1",
Content that you provide for indexing must conform to the index schema and include a unique string value for the document key. Prevectorized data is loaded into one or more vector fields, which can coexist with other fields containing nonvector content.
For data ingestion, you can use push or pull methodologies.
Use Documents - Index to load vector and nonvector data into an index. The push APIs for indexing are identical across all stable and preview versions. Use any of the following APIs to load documents:
POST https://{{search-service-name}}.search.windows.net/indexes/{{index-name}}/docs/index?api-version=2026-04-01
    "value": [
            "id": "1",
            "title": "Azure App Service",
            "content": "Azure App Service is a fully managed platform for building, deploying, and scaling web apps. You can host web apps, mobile app backends, and RESTful APIs. It supports a variety of programming languages and frameworks, such as .NET, Java, Node.js, Python, and PHP. The service offers built-in auto-scaling and load balancing capabilities. It also provides integration with other Azure services, such as Azure DevOps, GitHub, and Bitbucket.",
            "category": "Web",
            "titleVector": [
                -0.02250031754374504,
            "contentVector": [
                -0.024740582332015038,
            "@search.action": "upload"
            "id": "2",
            "title": "Azure Functions",
            "content": "Azure Functions is a serverless compute service that enables you to run code on-demand without having to manage infrastructure. It allows you to build and deploy event-driven applications that automatically scale with your workload. Functions support various languages, including C#, F#, Node.js, Python, and Java. It offers a variety of triggers and bindings to integrate with other Azure services and external services. You only pay for the compute time you consume.",
            "category": "Compute",
            "titleVector": [
                -0.020159931853413582,
            "contentVector": [
                -0.02780858241021633,
Query an index for vector content
For validation purposes, you can query the index using Search Explorer in the Azure portal or a REST API call. Because Azure AI Search can't convert a vector to human-readable text, try to return fields from the same document that provide evidence of the match. For example, if the vector query targets the titleVector field, you could select title for the search results.
Fields must be attributed as retrievable to be included in the results.
  • Review the indexes in Search management > Indexes to view index size all-up and vector index size. A positive vector index size indicates vectors are present.
  • Use Search Explorer to query an index. Search Explorer has two views: Query view (default) and JSON view.
    • Set Query options > Hide vector values in search results for more readable results.
    • Use the JSON view for vector queries. You can paste a JSON definition of the vector query you want to execute. If your index has a vectorizer assignment, you can also use the built-in text-to-vector or image-to-vector conversion. For more information about image search, see Quickstart: Search for images in Search Explorer.
    • Use the default Query view for a quick confirmation that the index contains vectors. The query view is for full-text search. Although you can't use it for vector queries, you can send an empty search (search=*) to check for content. The content of all fields, including vector fields, is returned as plain text.
For more information, see Create a vector query.
Update a vector index
To update a vector index, modify the schema and reload documents to populate new fields. APIs for schema updates include Create or Update Index (REST), CreateOrUpdateIndex in the Azure SDK for .NET, create_or_update_index in the Azure SDK for Python, and similar methods in other Azure SDKs.
For standard guidance on updating an index, see Update or rebuild an index.
Key points include:
  • Drop and full index rebuild is often required for updates to and deletion of existing fields.
  • You can make the following modifications with no rebuild requirement:
    • Add new fields to a fields collection.
    • Add new vector configurations, assigned to new fields but not existing fields that are already vectorized.
    • Change retrievable (values are true or false) on an existing field. Vector fields must be searchable and retrievable, but if you want to disable access to a vector field in situations where drop and rebuild isn't feasible, you can set retrievable to false.
Next steps
As a next step, we recommend Create a vector query.
Code samples in the azure-search-vector-samples repository demonstrate end-to-end workflows that include schema definition, vectorization, indexing, and queries.
There's demo code for Python, C#, and JavaScript.
