How to fix my power point issue which is not repair now
Vaibhav Dubey 0 Reputation points
2026-08-03T10:13:12.4733333+00:00
my power point not working properly and not able to open ,please give us solution
Microsoft 365 and Office | PowerPoint | For home | Other
1 answer
  1. DaveM121 947.3K Reputation points Independent Advisor
    2026-08-03T10:51:33.5433333+00:00
    Please provide more information on this problem.
    Is this problem affecting one PowerPoint presentation, or are you unable to open the PowerPoint app and if so, what error is indicates, are you seeing an error dialog with a 'Repair Now' button and is that failing to resolve the problem, please provide a screenshot of any error you may be seeing.
    If you are seeing the popup error with the 'Repair Now' button, before proceeding to repair your Office apps, log into your Microsoft account on this link (https://account.microsoft.com/services/) to ensure your Office licence or subscription is correctly listed there.
    Then, open the Settings App (gear icon on your Start Menu)
    Go to Apps - Installed Apps, then scroll down to find Microsoft Office
    Select that and choose Modify - Online Repair
    That should fix any issues with your Office Installation.
