in setting option power and battery not opening
nikhil syal 45 Reputation points
2026-05-25T02:17:53.1733333+00:00
in setting option i tried to open power and battery and its not opening
Windows for home | Windows 11 | Sleep and Power on, off
Locked Question. You can vote on whether it's helpful, but you can't add comments or replies or follow the question.
AI answer
2026-05-25T02:18:04.9633333+00:00
Try the following steps in order. After each step, test whether Settings > System > Power & battery opens.
  1. Open Power & battery from a direct link
    • Press Windows key + R.
    • Paste this and press Enter:
      • ms-settings:batterysaver?activationSource=SMC-IA-4027667
    • This should open the Power & battery page directly. If this works, use it once to adjust settings; the normal Settings navigation may start working again afterward.
  2. Use the Get Help guided walkthrough for power settings
    • Open a browser and sign in to Windows if needed.
    • Use the Guided walkthrough in Get Help for power and battery settings: it can diagnose common issues with the Power & battery page and suggest fixes.
  3. Check power settings via alternative UI
    • Open Control Panel.
    • Go to Power Options.
    • Use Change plan settings and Change advanced power settings to adjust screen, sleep, and battery-related options while the Settings page is not opening.
If none of these steps allow access to Power & battery, further OS repair or reset steps outside the provided guidance may be required.
References:
40+ people found this answer helpful.
1 additional answer
  1. Deleted
    This answer has been deleted due to a violation of our Code of Conduct. The answer was manually reported or identified through automated detection before action was taken. Please refer to our Code of Conduct for more information.
    Comments have been turned off. Learn more
