How can I fix my audio settings if my volume slider is disabled and I can't hear anything out of my laptop's speakers
Jill Cunningham 25 Reputation points
2026-01-31T22:11:52.1933333+00:00
on my control panel in the bottom right corner of my computer the speaker icon has a grey X over it and when I go to adjust volume the volume slider is disabled/greyed out
Windows for home | Windows 11 | Devices and drivers
John DeV 170.6K Reputation points Independent Advisor
2026-01-31T22:51:52.4433333+00:00
Hi, good day!
  • When was the last time it worked properly?
  • What is the exact make and model of your computer?
Press Windows key+R to open Run then type: msinfo32
Press Enter
Please take a screenshot of the System Information window and post it in your next response. Note: Don't include any personal information or sensitive data as Microsoft Q&A is a public forum.
Please try the following methods below.
Run the Troubleshooter
Press Windows key+I to open Settings
Select System > Troubleshoot
Select "Other troubleshooters" then Run "Audio"
If the internal speaker is missing, the driver may be corrupted.
Open Device Manager again
Click View > Show hidden devices
Expand Sound, video and game controllers.
Right-click your audio device (e.g. Realtek Audio, Intel Smart Sound, Conexant, etc.)
Click Uninstall device.
Tick "Attempt to remove the driver for this device" box
Restart your computer.
Windows will reinstall the driver automatically.
If this does not work, it would be best to visit your manufacturer's support page to download and install the latest Audio driver for your device.
I look forward to receiving your update and I'm willing to collaborate with you till we resolve the issue. Do keep me informed by clicking "Add comment" below.
5 people found this answer helpful.
2 additional answers
  1. AI answer
    2026-01-31T22:11:59.6633333+00:00
    If your volume slider is disabled and you see a grey X over the speaker icon, it typically indicates that your audio device is not recognized or there is an issue with the audio drivers. Here are some steps you can take to troubleshoot and potentially fix the issue:
    1. Check Audio Device Status: Open the Device Manager by right-clicking on the Start button and selecting "Device Manager." Under "Sound, video and game controllers," check if your audio device is listed and if there are any warning icons.
    2. Update Audio Drivers: Right-click on your audio device in Device Manager and select "Update driver." Choose "Search automatically for updated driver software" to see if there are any updates available.
    3. Set Correct Playback Device: Right-click the speaker icon in the taskbar, select "Open Sound settings," and ensure that the correct output device (your laptop speakers) is selected.
    4. Run Windows Troubleshooter: Go to Settings > System > Sound, and under "Output," click on "Troubleshoot" to run the audio troubleshooter. This can help identify and fix issues automatically.
    5. Check for Windows Updates: Sometimes, audio issues can be resolved with cumulative updates. Go to Settings > Update & Security > Windows Update and check for updates.
    6. BIOS/Firmware Check: Ensure your BIOS is up to date, as audio initialization can sometimes depend on firmware. Check the manufacturer's website for updates.
    If none of these steps resolve the issue, it may be a hardware problem, and you might need to contact your laptop's support for further assistance.
  2. ershadjan alimi 0 Reputation points
    2026-09-25T18:29:27+00:00
    من ص صدای ویدیو وموزیک را ازلپ تاپم شنیده نمی توانم کارنمی کند لطفا صدای انرا فکس کنید
