My Bose wired headphones will not connect/operate with my laptop
Mike Eaton 20 Reputation points
2025-07-15T09:54:39.4833333+00:00
I have an HP Probook 450 G* laptop and a set of Bose QuietComfort 15 wired Headphones. The Headphones work correctly with other devices but will not connect to the laptop. I get a message that a driver is needed. However, when I search for and try to install the driver I receive a message that
An error occurred during the installation. The driver installation file for this device is missing a necessary entry. Contact your hardware vendor.
I have tried contacting HP but just go round and round with Troubleshooting systems/files which state they are not available and refer me to Microsoft. When I tried troubleshooting with Microsoft I have been shunt here. VERY FRUSTRATING.
Can anybody help please?
Mike
Outlook | Windows | Classic Outlook for Windows | For business
Jayden-P 26,210 Reputation points Microsoft External Staff Moderator
2025-07-15T10:45:56.7566667+00:00
Hi @Mike Eaton
Thanks for posting in the Microsoft Q&A forum.
To assist you better, I will need more information.
  • Which version of Windows are you using?
  • You mentioned other devices worked properly, are they phones or other laptops?
  • Can you please share a screenshot with the error "A driver is needed"?
Meanwhile, I'll try my best to assist you.
First, press Windows + X > Device Manager > Audio inputs and outputs.
If it connected via 3.5mm Audio Jack, you won’t see a specific “Bose” entry. Instead, the system uses the built-in audio driver, and you’ll see something like this:
User's image
If it shows up, you can right click, choose Properties > Driver > Update Driver.
Please let me know if it works for you.
If not, we can find another approach.
If the answer is helpful, please click "Accept Answer" and kindly upvote it. If you have extra questions about this answer, please click "Comment".
User's image
2 additional answers
  1. Mike Eaton 20 Reputation points
    2025-07-15T10:53:13.7333333+00:00
    I have just been able to contact HP support and have been given the solution which involved uninstalling the Realtek driver and rebooting the laptop when the correct driver was installed and the problem resolved.
    It appears that my question has now been deleted because I unwittingly breached the Code of Conduct.
    As the problem is resolved it does not matter. I am grateful for your response.
  2. Deleted
    This answer has been deleted due to a violation of our Code of Conduct. The answer was manually reported or identified through automated detection before action was taken. Please refer to our Code of Conduct for more information.
    Comments have been turned off. Learn more
