Edge will not close - any help please?
2025-05-17T09:07:34+00:00
Ok - This morning I opened Edge (w10) and when I clicked the X to close, it would not close. I tried to minimise and click close, still would not work. I can only close it via task manager or rebooting. Nothing has chnaged since last night, so no idea why it has happened. Is there a simple answer as in apps both uninstall and modify are grayed out.
The PC is mine, not a work one and is W10.
Keith
PS - Just tried with my w10 laptop, am able to close edge as normal. So have no idea why the desktop is playing up. Is there a solution?
Microsoft Edge | Other | Windows 10
  1. Deleted
    This answer has been deleted due to a violation of our Code of Conduct. The answer was manually reported or identified through automated detection before action was taken. Please refer to our Code of Conduct for more information.
    Comments have been turned off. Learn more
  2. Virginia M 42,505 Reputation points Independent Advisor
    2025-05-17T13:38:15+00:00
    Hello, I’m Virginia, a fellow user like yourself.
    Sorry to hear you’re experiencing problems.
    Does the problem occur when using InPrivate mode?
    Have you tried resetting Edge?
    Please try these cmds:
    Right click on start & choose powershell/terminal with admin & type/copy & paste these cmds one at a time then click Enter:
    SFC /SCANNOW
    DISM /Online /Cleanup-Image /StartComponentCleanup
    DISM /Online /Cleanup-Image /RestoreHealth
    SFC /SCANNOW
    Yes the Sfc cmd is run twice.
    10 people found this answer helpful.
