2019-06-15T07:08:49+00:00
First bought (Jan,2018)
Update 3 9/1/19:
Conclusion:
P.S.
OR
Worst case = both.
    2019-08-16T18:15:22+00:00
    You need to make the decision on spending $450 for an out of warranty
    refurbished replacement. If you are in the US (there are also 5 stores in Canada
    and 1 each in London, UK
    and Sydney, AU) you should go to the closest physical retail Microsoft Store
    https://www.microsoft.com/en-us/store/locations/find-a-store - if you are not
    able to get to a store, contact support
    https://support.microsoft.com/en-us/help/4051701/global-customer-service-phone-numbers.
    Your best option is to go to a Store, if at all possible.
    2019-08-16T18:43:08+00:00
    Dear Barb,
    Thank you for your response, but surprised how tye expensive product get detorated within 2 years. Even the cellphone battery last more then this product.
    I cant imagine that Microsoft products have such a short life span.
    I would also discouraged my other colleagues not to invest in such abd product. Microsoft must get these technical failure replaced without any cost.
    Thank you again foe provide us the option of replacement.
    2019-08-16T18:43:17+00:00
    Hi All:
    I had the exact same problem, with battery capacity falling to 30% after 300-odd cycles and about 1.5 years' use.
    After trying the usual software fixes as detailed above, I took it to the local MS Store and exchanged it for a refurb.  My cost was $ 614 Cdn ($550 + tax).
    This is a common problem that looks like a design weakness.  I'm surprised there is no consideration of this.
    2019-08-16T19:04:40+00:00
    To all concerned:
    Perhaps the issue is that we are working within the confines of our individual issue and not looking at the broader output.  I'm not into social media, as a case in point I remember the memory typewriter, mimeograph and revolutionary drum fax machine as vital pieces of equipment of the technologically advanced office.
    Perhaps someone with today's savvy could guide us towards a class action, won't meant much but I know I'll feel better.
  5. Barb Bowman 80,820 Reputation points MVP Volunteer Moderator
    2019-08-16T19:06:39+00:00
    It took them 9 months+ to acknowledge battery issues with SP3 and the fixes didn't solve everything. This issue is just starting to trend. I keep emailing an internal contact on it but no replies.
