2019-06-15T07:08:49+00:00
First bought (Jan,2018)
Update 3 9/1/19:
Conclusion:
P.S.
OR
Worst case = both.
    2019-08-13T15:28:42+00:00
    Same issue on my Surface 5th gen.  After less than 2 years and 307 cycles, battery capacity is less than 1/10th at 3480 mWh full charge   This is the third Surface (2, 4 and 5) I suspect we have a defective battery or poor engineering design.  So nice to know that Microsoft backs their products.
    Last piece of MS hardware I'll purchase.
    2019-08-13T15:36:45+00:00
    ouch. I'd be interested in seeing the full battery report if you could upload it to OneDrive and share a link.
    2019-08-16T14:23:11+00:00
    As per your request:
    Please find the link to the battery report, I would appreciate any observations or suggestions that may negate having to replace the battery.
    https://1drv.ms/b/s!AqroDCEmEjufgqVUbBL0KZMy8nPSIg
    2019-08-16T14:37:44+00:00
    Yuck. Sure looks like battery is failing.
    We can try removing and reinstalling the battery driver. To do this:
    1. Plug in your Surface.
    2. Select the search box in the taskbar, enter device manager, and in the search results, select Device Manager.
    3. Select the arrow next to the Batteries category.
    4. Double-tap or double-click Microsoft ACPI-Compliant Control Method Battery, select the Driver tab, and select Uninstall > OK. (Or you can right-click Microsoft ACPI-Compliant Control Method Battery and select Uninstall.)
    5. Leave your Surface plugged in.
    6. After you remove the battery driver, install Surface and Windows updates. Go to Settings, Updates, and check for updates manually and install any updates that are available.
    7. Restart your Surface and test to see if anything has changed.
    I'm not too hopeful that this will fix the issue, but it is worth trying. Note that Microsoft does not replace batteries. They would replace the whole thing with a refurb. My own SP 2017 LTE had the SSD die and the replacement was a good one. I've not seen many SP2017 battery failures (yet). I've sent this thread in to an internal contact, but have not received a reply (probably won't).
    2019-08-16T15:39:17+00:00
    Thanks Barb
    I've already tried reinstalling the ACPI driver.
    However appreciate the effort.
