2019-06-15T07:08:49+00:00
First bought (Jan,2018)
Update 3 9/1/19:
Conclusion:
P.S.
OR
Worst case = both.
    2019-06-15T09:40:55+00:00
    I'd try two things. Otherwise it would appear to be a failing battery. First,
    try to recalibrate the battery - good tutorial at
    https://www.windowscentral.com/how-calibrate-battery-your-windows-10-laptop
    Based on your description and the report, I don't think recalibrating will work
    but you should try it. Also try reinstalling the battery drivers:
    We can try removing and reinstalling the battery driver. To do this:
    1. Plug in your Surface.
    2. Select the search box in the taskbar, enter device manager, and in the search
      results, select Device Manager.
    3. Select the arrow next to the Batteries category.
    4. Double-tap or double-click Microsoft ACPI-Compliant Control Method Battery,
      select the Driver tab, and select Uninstall > OK. (Or you can right-click
      Microsoft ACPI-Compliant Control Method Battery and select Uninstall.)
    5. Leave your Surface plugged in.
    6. After you remove the battery driver, install Surface and Windows updates. Go
      to Settings, Updates, and check for updates manually and install any updates
      that are available.
    7. Restart your Surface and test to see if anything has changed.
    2019-06-15T07:12:00+00:00
    Screenshots of my Battery Report: (Not fully charge as of now, but it seems full at 22,xxx.
    A few days ago it was at 9,000. (seems to swing from 22.000 to 9,000
