2019-06-15T07:08:49+00:00
First bought (Jan,2018)
Update 3 9/1/19:
Conclusion:
P.S.
OR
Worst case = both.
    2021-04-27T18:26:39+00:00
    Information is available online at How much does out-of-warranty service cost for your Surface device or accessory? (microsoft.com)
    For the US:
    For SP5, they do not replace just the battery, they replace the entire device with a refurb.
    2021-04-27T18:09:38+00:00
    Hi.  I'm in the same boat.  Bought Feb 2018.  Battery lasts 1-2 hours at most for simplistic computing tasks.
    I may have the option to go through my credit card company, which provides extra warranty coverage, but they will want some sort of documentation.  I have seen some discussion here that it would cost $500 to have Microsoft replace the battery (or device itself?)  How do I go about getting this in writing?  Do I have to open a support ticket?
    Any guidance is appreciated.  Thanks.
    2021-03-29T14:51:28+00:00
    Hi, I am Aniket Biswas.
    Lithium-Ion Batteries or any type of rechargeable batteries degrades over time while using. Mostly everyone should replace rechargeable battery after 2 to 3 years of usage. But if you are able to maintain some rules then you can extend the battery life.
    The rules are-
    1.Try to charge battery only up to 80%.
    2.Not drain it bellow 30%.
    3.Don't leave the battery in night to charge. Though it will not overcharge but trickle charging kicks in after battery gets 100% and still connected to a charger. When it trickle mode the battery charges to 100% then the charging circuit stops charging and let the battery slowly drain to a certain point like for example 95% then charging again kicks in and this cycle continues. And it causes battery to degrade.
    4.Don't charge battery too often.
    5.Avoid fast charging if not needed.
    By maintaining such rules you can extend battery life but lets be honest no one in daily life usage are able to follow such rules. So just replace them with time to time. Go for higher capacity battery. Try avoiding fast charging.
    I know the price are really high for Lithium-Polymer battery which shouldn't be.
    GOod Luck!
    2021-03-29T12:41:36+00:00
    Short answer: Nothing, I assume. Getting angry seems to be the only solution … :/
    2021-03-29T10:31:11+00:00
    The same here,
    I got my Surface Pro 5th gen in 2017 and at the end of 2020 the battery drain problem started.
    In generelly it is connected the most time connected to the power adapter.
    At this time iI got a problem with the power adapter too. I replaced it with a new (original Surface power adapter).
    The charge cycles: 323
    Battery capacity now is at 15450 mWh (standard 45000 mWh)
    Last complete charge was 34 %
    With this I have nearly 20 (a bit more with power saving) minutes to use the Surface in battery mode.
    What can I do?
    Best Regards
