2019-06-15T07:08:49+00:00
First bought (Jan,2018)
Update 3 9/1/19:
Conclusion:
P.S.
OR
Worst case = both.
    2019-07-18T10:30:09+00:00
    weeks passed by. The only way is to replace the device (Microsoft will refurbish/replace the device) and that will cost 450 - 500 USD.
    Considering it is JUST a battery problem. 450 USD doesn''t seem to worth. I'd rather save up to buy a new device with more repairability.
    Currentlyy, using it as a dock. If i go outside, it has to always be pluggen in. Kinda annoying.
    2019-07-17T09:30:17+00:00
    Please open an administrative cmd prompt and run powercfg /batteryreport.
    Please post the HTML file to OneDrive and share a link in a reply. We can try
    removing and reinstalling the battery driver. To do this:
    1. Plug in your Surface.
    2. Select the search box in the taskbar, enter device manager, and in the search
      results, select Device Manager.
    3. Select the arrow next to the Batteries category.
    4. Double-tap or double-click Microsoft ACPI-Compliant Control Method Battery,
      select the Driver tab, and select Uninstall > OK. (Or you can right-click
      Microsoft ACPI-Compliant Control Method Battery and select Uninstall.)
    5. Leave your Surface plugged in.
    6. After you remove the battery driver, install Surface and Windows updates. Go
      to Settings, Updates, and check for updates manually and install any updates
      that are available.
    7. Restart your Surface and test to see if anything has changed.
    2019-07-16T20:12:39+00:00
    Same problem, but I could somehow live with it, but now it is impossible to use as it show me 0 % battery and plugged in and it is really slow and I had to buy a new device, but I hope there could be some solution from Microsoft even the device is out of warranty, because I dont think that this should be normal just a little more than one year after purchase.
    9 people found this answer helpful.
    2019-06-15T11:05:10+00:00
    I think my battery capacity has been degraded.
    sadly, yes..
    2019-06-15T10:41:33+00:00
    Thank you very much for your suggestion.
    I have tried both options and they didn't work.
    3 people found this answer helpful.
