2019-06-15T07:08:49+00:00
First bought (Jan,2018)
Update 3 9/1/19:
Conclusion:
P.S.
OR
Worst case = both.
    2019-08-13T15:36:45+00:00
    ouch. I'd be interested in seeing the full battery report if you could upload it to OneDrive and share a link.
    Same issue on my Surface 5th gen.  After less than 2 years and 307 cycles, battery capacity is less than 1/10th at 3480 mWh full charge   This is the third Surface (2, 4 and 5) I suspect we have a defective battery or poor engineering design.  So nice to know that Microsoft backs their products.
    Last piece of MS hardware I'll purchase.
    2019-08-13T15:28:42+00:00
    2019-07-30T23:29:53+00:00
    I have pretty much the same problem on a Surface Pro 5 bought in January 2018.
    All indications are that the battery has fallen to 30% or so of design capacity.  This seems a very short time when MS Battery Report shows only 309 cycles.
    7 people found this answer helpful.
    2019-07-22T02:26:22+00:00
    Same issue here. I only use it a couple of times for my trips. I would expect it to last at least 4 ~5 years and not after a year and a half.
    3 people found this answer helpful.
    2019-07-22T00:28:22+00:00
    I have the same model Surface Pro (5th generation, 2017, i5, 256))  with same issue, its very unfortunate to buy Microsoft and invested more then $2000 USD for such a rubbish piece.
    If anyone got on know some solution let me know.
    Deep
    10 people found this answer helpful.
