2019-06-15T07:08:49+00:00
First bought (Jan,2018)
Update 3 9/1/19:
Conclusion:
P.S.
OR
Worst case = both.
    2019-08-16T18:43:08+00:00
    Dear Barb,
    Thank you for your response, but surprised how tye expensive product get detorated within 2 years. Even the cellphone battery last more then this product.
    I cant imagine that Microsoft products have such a short life span.
    I would also discouraged my other colleagues not to invest in such abd product. Microsoft must get these technical failure replaced without any cost.
    Thank you again foe provide us the option of replacement.
    2019-08-16T18:15:22+00:00
    You need to make the decision on spending $450 for an out of warranty
    refurbished replacement. If you are in the US (there are also 5 stores in Canada
    and 1 each in London, UK
    and Sydney, AU) you should go to the closest physical retail Microsoft Store
    https://www.microsoft.com/en-us/store/locations/find-a-store - if you are not
    able to get to a store, contact support
    https://support.microsoft.com/en-us/help/4051701/global-customer-service-phone-numbers.
    Your best option is to go to a Store, if at all possible.
    2019-08-16T15:39:17+00:00
    Thanks Barb
    I've already tried reinstalling the ACPI driver.
    However appreciate the effort.
    2019-08-16T14:37:44+00:00
    Yuck. Sure looks like battery is failing.
    We can try removing and reinstalling the battery driver. To do this:
    1. Plug in your Surface.
    2. Select the search box in the taskbar, enter device manager, and in the search results, select Device Manager.
    3. Select the arrow next to the Batteries category.
    4. Double-tap or double-click Microsoft ACPI-Compliant Control Method Battery, select the Driver tab, and select Uninstall > OK. (Or you can right-click Microsoft ACPI-Compliant Control Method Battery and select Uninstall.)
    5. Leave your Surface plugged in.
    6. After you remove the battery driver, install Surface and Windows updates. Go to Settings, Updates, and check for updates manually and install any updates that are available.
    7. Restart your Surface and test to see if anything has changed.
    I'm not too hopeful that this will fix the issue, but it is worth trying. Note that Microsoft does not replace batteries. They would replace the whole thing with a refurb. My own SP 2017 LTE had the SSD die and the replacement was a good one. I've not seen many SP2017 battery failures (yet). I've sent this thread in to an internal contact, but have not received a reply (probably won't).
    2019-08-16T14:23:11+00:00
    As per your request:
    Please find the link to the battery report, I would appreciate any observations or suggestions that may negate having to replace the battery.
    https://1drv.ms/b/s!AqroDCEmEjufgqVUbBL0KZMy8nPSIg
