2019-06-15T07:08:49+00:00
First bought (Jan,2018)
Update 3 9/1/19:
Conclusion:
P.S.
OR
Worst case = both.
    2019-08-21T15:40:37+00:00
    I reported via the feedback hub as well, link here:  https://aka.ms/AA5vref
    Thanks
    Karen
    2019-08-21T15:25:59+00:00
    I've seen more than a few reports on SP2017 this past week that look like yours.
    When I asked an internal contact about this, he asked that people use the
    Feedback Hub to report a problem and share the link back in a reply here (also
    include that battery report in the problem report). To *me* this looks like a
    battery failure as the report shows degradation that goes back quite a bit.
    2019-08-21T14:38:48+00:00
    >would it be worth changing the battery or would that not help?
    the batteries in Surface are NOT replaceable. Please file feedback hub problem
    report using the app and share the link to it in a reply. Also I'd like to see a
    full battery report. Open an administrative cmd prompt and run *powercfg
    /batteryreport* - upload the entire HTML file it produces to OneDrive and share
    a link here and attach it to the problem report.
    Hi Barb
    Link to battery report:
    https://guesttalk-my.sharepoint.com/:u:/g/personal/karen\_foster\_guesttalk\_co\_uk/EV3JDkLu-P9Go8LF\_m6ApX0BqVLB-H9jeYCYOZo9LEyD\_A?e=qy51aO
    Thanks
    Karen
    2019-08-20T15:50:44+00:00
    2019-08-20T14:46:48+00:00
    Hi Barb
    I have exactly the same problem and its getting worse by the day. As its out of warranty anyway, would it be worth changing the battery or would that not help?
    Thanks
    Karen
