2019-06-15T07:08:49+00:00
First bought (Jan,2018)
Update 3 9/1/19:
Conclusion:
P.S.
OR
Worst case = both.
    2019-08-22T04:30:42+00:00
    Update 2:
    I just bought a new PC,Monitor and other devices since i need a computer to work. (1,700 USD)
    Anyway, does Microsoft actually care what's happenning ?
    Do they really check Feedback hub?
    And do people know it exists as i don't see people use and upvote threads.
    Do people who have the same problem realize this could be the the defect hardware?
    Of course most of them dont. They just buy a new one or get replacement $$$$.
    I cant wait to spend 500 usd (better buy a new one).
    Or wait to send to the nearest HQ (another country) which would take 1-2 weeks.
    I won't complain about my work and files. Because you know when you are working and suddenly your only computer is dead. Some files are not backed up on cloud.
    My battery drains faster than i can say disappointing.
    Just kidding. Actually i cant turn my surface pro on at all.
    2019-08-22T03:04:49+00:00
    Just a follow-up on my last post...
    It seems that there have been 3 firmware updates for the Surface Pro 2017 (5th gen), which were supposedly aimed at battery stability/reliability issues. These were dated:
    August 2019
    September 2018
    March 2018
    I started noticing worsening battery issues roughly correlating with the Aug19 and Sep18 updates.
    2019-08-22T00:59:44+00:00
    I just saw this thread. I have pretty much the same issues on my SP 2017 I5 256gb. Any suggestion would be appreciated.
    1. Link to batteryreport...
    https://1drv.ms/u/s!AvjG\_MPfoiFz13KO3up\_kavHSEed
    1. I just filed a report on feedback hub about the issues, but not sure how to generate a public link to the report. Here is the text...
    "Roughly coinciding with a firmware upgrade in late 2018 (around Nov) for my SP5 2017 I5 256 gb, my battery has been experiencing significant capacity issues. A full charge lasts at most 3 hours on normal load (mostly spreadsheet, Word), which fluctuates wildly and has been decreasing. Percentage on the battery icon does not seem to correlate with actual capacity remaining. Sometimes, battery stays on 100% for an hour, but drops to about 60 or 70% in 20 minutes, after which the machine loses power without warning and shuts off without first going to sleep. Lately, batteryreport appears to be reporting random numbers for the full-charge capacity. Because the battery status is unreliable and the machine shuts off unpredictably, the only way I can use it now is to leave it plugged in. I have the latest firmware and system updates installed, but the problem only seems to be getting worse, giving me only about 2 hours on battery at most. The random unpredictability is the biggest issue."
    2019-08-21T17:28:49+00:00
    1. please run a battery report and post a link to the HTML file here
    1. please file a feedback hub problem report from the problem SP2017 and share a
    link to this report and reply with that link
    2019-08-21T17:11:06+00:00
    I work in IT and one of my users with a SP (2017) is having the same issue with diminished battery life. I checked every setting I could think of, checked for apps misbehaving. My finding are the same, battery life has drastically been reduced, either because the battery thinks its charged to 100% and it's not similar to the issues with the SP4's, or the battery is just degrading rapidly.
