2019-06-15T07:08:49+00:00
First bought (Jan,2018)
Update 3 9/1/19:
Conclusion:
P.S.
OR
Worst case = both.
    2019-08-22T14:46:48+00:00
    Anyway, does Microsoft actually care what's happenning ?
    Do they really check Feedback hub?
    I believe they're aware. But they're smart and just watch things from the dark and keep silent. They're not held accountable in any way.
    This is a psychology game. When you want something so badly, you do your best to get your voice listened. But after 1 day, 2 days, then X days without a reply, you'll forget about what you wanted.
    2019-08-22T14:26:37+00:00
    Just a follow-up on my last post...
    It seems that there have been 3 firmware updates for the Surface Pro 2017 (5th gen), which were supposedly aimed at battery stability/reliability issues. These were dated:
    August 2019
    September 2018
    March 2018
    I started noticing worsening battery issues roughly correlating with the Aug19 and Sep18 updates.
    This is good to know. Thanks for sharing.
    I used to accept battery degradation as a matter of fact on Windows OS, as it's never as good as it's advertised. Thus I didn't really pay close attention to when the problem started on my device. I only started monitoring the battery usage when noticing a huge loss in battery power earlier this year, so it could well have started after the Sep18 updates.
    As for this:
    • "Because the battery status is unreliable and the machine shuts off unpredictably, the only way I can use it now is to leave it plugged in. I have the latest firmware and system updates installed, but the problem only seems to be getting worse, giving me only about 2 hours on battery at most."
    You seem to be observing all the same symptoms as I did, except that your battery is still "good" and your device is still working. When did you purchase the device? Is it still on warranty?
    2019-08-22T13:16:47+00:00
    You described to a tee the failure sequence, including the shutting down on its' own.
    To that end I suggest you copy all of your files, as over this past weekend the final curtain fell.  Unit will no longer boot up; appears to have power so I suspect the SD drive just crapped out.
    Thanks for sharing the idea, Philip.
    I just can't believe it's an SSD problem. All the symptoms led to battery and then power management failure. When the device shut down on its own, it remained OFF for a few seconds before it came ON again, still on its own. As far as I can tell, the power was too weak and the device had to rest for some time to get enough power to survive. This may also explain why I saw "discharging" from the battery indicator at times. And now it seems there's no way for the device to have power to get up.
    2019-08-22T09:58:00+00:00
    >Lately, batteryreport appears to be reporting random numbers for the full-charge capacity
    I can see that. We can try removing and reinstalling the battery driver. To do
    this:
    1. Plug in your Surface.
    2. Select the search box in the taskbar, enter device manager, and in the search
    results, select Device Manager.
    1. Select the arrow next to the Batteries category.
    2. Double-tap or double-click Microsoft ACPI-Compliant Control Method Battery,
    select the Driver tab, and select Uninstall > OK. (Or you can right-click
    Microsoft ACPI-Compliant Control Method Battery and select Uninstall.)
    1. Leave your Surface plugged in.
    2. After you remove the battery driver, install Surface and Windows updates. Go
    to Settings, Updates, and check for updates manually and install any updates
    that are available.
    1. Restart your Surface and test to see if anything has changed.
    2019-08-22T04:40:25+00:00
    Same. I just bought a brand new PC.
    I thought my surface could last 4 - 5 years.
    Next laptop will not be from Microsoft if they won't fix this.
