2019-06-15T07:08:49+00:00
First bought (Jan,2018)
Update 3 9/1/19:
Conclusion:
P.S.
OR
Worst case = both.
    2019-08-22T17:25:15+00:00
    they are looking for feedback reports. here is how to get the link so that you
    can copy and paste it into a reply here
    https://www.tenforums.com/tutorials/130174-share-feedback-feedback-hub-windows-10-a.html
    to be honest, *I* don't know what to think of the sudden flurry of reports on
    this issue that started after the recent firmware updates. there is clearly a
    trend *here in the forum*. but there do not seem to be a lot of feedback hub
    reports.
    2019-08-22T15:12:04+00:00
    Excellent point.  I've done all I could to resolve and have come to conclusion that short of spending good money after bad, I now own a proverbial brick; albeit a slim and lightweight  version, but useless nonetheless.
    Back to point.  I also use a 4th generation unit, so I'm anxious to hear from anyone who might have experienced similar issues with the 4th gen model.
    2019-08-22T15:07:43+00:00
    Thanks, vdn88.
    Unfortunately, I bought my SP5 in Nov 2017 and it is out of warranty.
    But in defense of Microsoft, I have a SP1 and a SP2. Skipped gen 3 and 4 but bought a SP 2017. And if I haven't seen this thread, I would have bought a SP6 since the battery issue is making my SP 2017 practically a desktop (but I don't work at a desk :-). The SP2 is my default laptop now.
    2019-08-22T14:59:34+00:00
    Thanks, Barb.
    I had re-installed the Battery driver previously (multiple times) and that didn't solve the problem.
    But having seen your suggestion for many of the other posters, I tried that again last night. After that, according to the battery report, the full capacity seemed to have been reset to 34290 mWh. The battery icon started at 100% and seemed to be discharging at about the right rate (as I was looping through continuously on youtube), so I was hopeful for a moment. But power then cut out at 77% without the machine going to suspend. According to batteryreport, it seems to think it had 26,540 mWh left when machine turned off by itself.
    But I'll try another charge/discharge cycle tonight and report back. Thanks.
    2019-08-22T14:51:37+00:00
    I have the same problem with my Surface Pro i5, 256.
    Starting to notice battery only lasting a couple of hours on basic tasks. So frustrating. Been checking the battery report and its only had a cycle count of 255 and the battery capacity has dropped to 34,640mWh.
