2019-06-15T07:08:49+00:00
First bought (Jan,2018)
Update 3 9/1/19:
Conclusion:
P.S.
OR
Worst case = both.
    2019-08-23T03:26:36+00:00
    BTW, I cannot provide the battery report since it is inside a dead surface now.  It is less than 2 years old ><
    2019-08-23T03:24:58+00:00
    I have a surface pro 5 that I actively keep up to date with windows update. Recently experienced increasingly shorter battery life, with very slow performance, then a few bouts of shutdown upon removal of power supply even though the battery indicates full charge, and then it no longer boots.... Anyone has this issue?
    My machine died even though powercfg /batteryreport recently started showing 101%, up from the previous 30%/50%. What do your reports show?
    If you are experiencing diminishing performance and battery life, please consider doing backups actively.  I now have a dead Surface on hand that does not boot.
    Crossposted from  https://mspoweruser.com/battery-issues-strike-surface-users-once-again-with-new-surface-pro-5-and-6-tablets-affected/
    2019-08-22T23:24:52+00:00
    Link to my feedback hub report...
    https://aka.ms/AA5wh2x
    2019-08-22T17:37:58+00:00
    there are companies that can change the battery or try a batpower  power bank depending on the size you purchase they can charge a surface up to 2 times
  5. Barb Bowman 80,820 Reputation points MVP Volunteer Moderator
    2019-08-22T17:26:56+00:00
    Please upload the complete battery report html file to OneDrive and share a link
    here. Also, please use the Feedback Hub App to file a problem report and share a
    link to that report in a reply here.
