2019-06-15T07:08:49+00:00
First bought (Jan,2018)
Update 3 9/1/19:
Conclusion:
P.S.
OR
Worst case = both.
    2019-08-25T10:12:27+00:00
    Microsoft tells me that they are working on battery issues, and I keep asking
    them to post something officially in this forum.
    Thanks Barb. Your efforts are much appreciated. And I have the same hope as Cai, since my surface is also dead now. It really needs some way to get some power.
    2019-08-25T10:08:32+00:00
    Yeah the battery indicator was totally unreliable. It took ~20min to reach 100% when plugged in, a few minutes to drain normally upon unplugged, then suddenly it would either hibernate or shut down, depending on the actual battery level I think. And it didn't matter how long I kept the device plugged in. As soon as it was unplugged, the same symptoms were observed.
    2019-08-25T10:02:27+00:00
    Yes, probably getting it fixed today by a computer shop.
    Ah, this is something I haven't thought of (I've been using my old laptop since my surface was dead). It would be great if you can share what is wrong, how it's fixed, and how much it costs (of course after the shop has completed their work). Thanks in advance.
    2019-08-25T09:57:55+00:00
    I hope it includes some way to jump start and reset a dead/non responsive surface...
  5. Barb Bowman 80,820 Reputation points MVP Volunteer Moderator
    2019-08-25T09:38:06+00:00
