Surface Pro 3 LGC Battery Degradation
2017-02-16T00:04:44+00:00
Split from this thread.
It was suggested that I open a new thread for this issue that I am having.
Since the Win 10 Anniversary update, I was not able to turn on my Surface Pro 3 i7 512GB with LGC LGC Battery without having it plugged in with the power supply or docking (I own a total of Three Surface Pro 3 Docks at home and 2 offices). It always said "82%, Plugged in, Not Charging", and would always instantly turn off once I pulled off the power supply tab.
I had spoke with a Technical Agent online, had my Pro 3 remote accessed, did all the proposed solutions, and even had a call from Bellevue, WA (I live in Hong Kong) before I found out that it was a software issue as stated by Microsoft.
With Auto Update turned on, I was notified that I should restart my Pro 3 this morning while I was on the docking station. I was happy that this issue was going to be resolved, but now I am disappointed that this firmware update did nothing for my Pro 3.
I'm hoping that someone out there has some suggestions.
Thank You.
Surface | Surface Pro | Display and screen
    2016-09-12T00:52:44+00:00
    Here's my current battery report...
          Battery report
    COMPUTER NAME HOMESURFACE
    SYSTEM PRODUCT NAME Microsoft Corporation Surface Pro 3
    BIOS 3.11.1550 06/30/2016
    OS BUILD 14393.103.amd64fre.rs1_release_inmarket.160819-1924
    PLATFORM ROLE Slate
    CONNECTED STANDBY Supported
    REPORT TIME 2016-09-11 20:49:08
    Installed batteries
    Information about each currently installed battery
    NAME X883815
    MANUFACTURER LGC-LGC
    SERIAL NUMBER 1151211524
    CHEMISTRY LION
    DESIGN CAPACITY 42,157 mWh
    FULL CHARGE CAPACITY 39,611 mWh
    CYCLE COUNT 42
    Recent usage
    Power states over the last 3 days
    2016-09-08 21:01:00 Active AC 80 % 31,525 mWh
    2016-09-09 01:18:33 Connected standby AC 80 % 31,502 mWh
    01:18:34 Suspended 80 % 31,502 mWh
    01:18:34 Report generated AC 80 % 31,502 mWh
    Battery usage
    Battery drains over the last 3 days
    Usage history
    History of system usage on AC and battery
    2016-08-26 - 2016-09-02 0:02:56 - 127:23:00 64:56:31
    2016-09-03 - - - 11:03:39
    2016-09-04 - - - -
    2016-09-05 - - 0:58:28 -
    2016-09-06 - - 2:04:48 0:17:49
    2016-09-07 - - 23:59:59 -
    2016-09-08 - - 23:59:56 -
    2016-09-09 - - 1:18:31 -
    Battery capacity history
    Charge capacity history of the system's batteries
    2016-08-26 - 2016-09-02 39,610 mWh 42,156 mWh
    2016-09-03 39,611 mWh 42,157 mWh
    2016-09-04 39,611 mWh 42,157 mWh
    2016-09-05 39,611 mWh 42,157 mWh
    2016-09-06 39,611 mWh 42,157 mWh
    2016-09-07 39,611 mWh 42,157 mWh
    2016-09-08 39,611 mWh 42,157 mWh
    2016-09-09 39,611 mWh 42,157 mWh
    Battery life estimates
    Battery life estimates based on observed drains
    2016-08-26 - 2016-09-02 4:37:57 - 4:55:49 -
    2016-09-03 - - - -
    2016-09-04 - - - -
    2016-09-05 - - - -
    2016-09-06 - - - -
    2016-09-07 - - - -
    2016-09-08 - - - -
    2016-09-09 - - - -
    Current estimate of battery life based on all observed drains since OS install
    Since OS install 4:37:58 - 4:55:50 -
    2016-09-12T00:11:03+00:00
    I would like to add mine also, it seems I have the same issue.
    I don't know where else to post this:
    Battery report
    COMPUTER NAME BPSURFACE
    BIOS 3.11.1150 12/09/2015
    OS BUILD 9600.18423.amd64fre.winblue_ltsb.160723-0600
    PLATFORM ROLE Slate
    REPORT TIME 2016-09-11 20:05:18
    Installed batteries
    NAME X883815
    SERIAL NUMBER 1164515844
    CHEMISTRY LION
    FULL CHARGE CAPACITY 42,598 mWh
    CYCLE COUNT 5
    Recent usage
    2016-09-09 19:40:55 Active AC - -
    19:50:56 Connected standby AC - -
    20:06:23 Suspended - -
    20:09:37 Active AC - -
    20:16:00 Battery changed AC - -
    20:16:00 Active AC - -
    20:22:00 Battery changed AC - -
    20:22:00 Suspended - -
    20:25:45 Active AC - -
    20:35:35 Connected standby AC - -
    20:42:28 Active AC - -
    20:48:00 Suspended - -
    20:54:56 Active AC - -
    21:00:00 Suspended - -
    21:09:23 Battery changed AC - -
    21:09:23 Active AC - -
    21:09:23 Suspended - -
    21:09:26 Active AC - -
    22:58:00 Suspended - -
    23:01:45 Battery changed AC - -
    23:01:45 Active AC - -
    23:01:45 Suspended - -
    23:01:42 Battery changed AC - -
    23:01:42 Active AC - -
    23:39:37 Connected standby AC - -
    23:51:10 Active AC - -
    23:51:13 Connected standby AC - -
    2016-09-11 17:49:55 Suspended - -
    19:57:01 Battery changed AC - -
    19:57:01 Active AC - -
    20:03:00 Report generated AC - -
    Battery usage
    Usage history
    2016-09-06 - - 23:59:59 -
    2016-09-08 - - 23:59:59 -
    2016-09-09 - - 22:50:11 0:42:36
    2016-09-10 - - - 23:59:47
    2016-09-06 42,598 mWh 42,157 mWh
    2016-09-07 42,598 mWh 42,157 mWh
    2016-09-08 42,598 mWh 42,157 mWh
    2016-09-09 37,591 mWh 37,202 mWh
    2016-09-10 - -
    2016-09-06 - - - -
    2016-09-07 - - - -
    2016-09-08 - - - -
    2016-09-09 - - - -
    2016-09-10 - - - -
    Since OS install - - - -
    2016-09-11T19:57:53+00:00
    I haven't tried uninstalling the battery driver because I assumed that it was a calibration problem. I posted as a separate thread because the post at the top of this thread didn't seem to relate in any way to my problem. I then got an email saying that it had been moved to a Discussion thread, then another saying that it had been moved again to a Question thread, and that I should have posted it as a Question in the first place - which I had. So I'm more confused than ever.
    You say something different is happening here, and I can believe that. But it started the next time I used the Surface after the firmware update was installed.
    Last night I uninstalled the battery driver without deleting it and then restarted. I took the Surface out today to use on-the-go and got about an hour and a half use before it shut down. In other words, nothing seems to have changed.
    2016-09-09T21:03:48+00:00
    The firmware was for Simplo batteries only. Something different is happening here. Have you tried uninstalling the battery driver (don't delete it) and restarting?
    2016-09-09T20:56:24+00:00
    The recent firmware update was installed on my Surface Pro 3 although it has the LGC battery. Before the update, I was getting over 4 hours from the battery. Now I'm lucky if it goes over 1 and a half hours before turning itself off. I've tried running the battery down now and again and recharging and it has crept up from about 1'20" to about 1'30" but I was expecting it to calibrate faster that it has.
    Is there anything I can do about this?
    I just did a battery report and uploaded it to my Dropbox, in case it's useful.
    https://dl.dropboxusercontent.com/u/254064/surface-pro-3-battery-report.html
