Battery drain overnight while shutdown
2019-08-17T15:39:13+00:00
Lately, after I shutdown (full shutdown, not sleep or hibernate) my fully charged Surface Laptop 2 at night, I turn it on in the morning and find that the battery has lost around 25% power overnight! What's going on and how can I fix this?
The laptop is only about 6 months old and the battery seems to be in good health.
I've reported this on the MS Feedback Hub. Please upvote it so that it gains attention: https://aka.ms/AA5w24b
Also be sure to report there as well if you are experiencing this issue.
Barb Bowman 80,820 Reputation points MVP Volunteer Moderator
2019-10-11T17:10:26+00:00
Please see https://support.microsoft.com/en-us/help/4469839/surface-laptop-2-update-history
This should be available on Windows Update:
October 10 release
The following updates are available for all Surface Laptop 2 devices running Windows 10 April 2018 Update, version 1803 or greater:
Windows Update History Name Device Manager Name
Surface – Firmware – 145.501.139.0 Surface System Aggregator– Firmware<br><br><ul><br><li><span>145.501.139.0 helps improve battery life.</span></li></ul>
379 additional answers
    2019-09-27T20:41:59+00:00
    ok, I tried your solution and, yes it improve the battery performance: after SMT disabling and the battery calibration (one cycle of complete discharge and one of full charge), in one hours only the 23% of discharge (from 100%).
    Thanks for your suggestion
    However, it could be only a temporary solution in waiting for an update to fix the August update troubles.
    Very nice...  Jose, recommended to drain the battery on more Time, just for a full recalibration.  Then your Surface should be as normal like before with out the August update.  Yes this fixed things for now until the next round of firmware is stable and ready with SMT
  2. Deleted
    This answer has been deleted due to a violation of our Code of Conduct. The answer was manually reported or identified through automated detection before action was taken. Please refer to our Code of Conduct for more information.
    Comments have been turned off. Learn more
    2019-08-17T15:44:24+00:00
    Note the overnight drops on 2019-08-16 from 100% to 72% and 2019-08-17 from 98% to 73%.
    Recent usage
    Power states over the last 3 days
    2019-08-1411:41:00 Active Battery 52 % 25,530 mWh
    11:42:02 Connected standby Battery 52 % 25,060 mWh
    12:54:33 Connected standby AC 51 % 24,880 mWh
    12:54:34 Active AC 51 % 24,880 mWh
    14:19:51 Connected standby AC 99 % 48,150 mWh
    14:22:03 Active AC 99 % 48,150 mWh
    16:19:24 Active Battery 100 % 48,400 mWh
    16:21:53 Connected standby Battery 100 % 48,400 mWh
    21:06:00 Connected standby AC 100 % 48,400 mWh
    21:06:02 Active AC 100 % 48,400 mWh
    23:20:25 Connected standby AC 100 % 48,400 mWh
    2019-08-1500:48:35 Active AC 100 % 48,400 mWh
    00:49:47 Connected standby AC 100 % 48,400 mWh
    00:49:47 Suspended 100 % 48,400 mWh
    09:15:01 Active AC 74 % 35,810 mWh
    10:03:14 Active Battery 95 % 46,360 mWh
    10:03:18 Active AC 97 % 47,020 mWh
    10:09:10 Active Battery 97 % 47,020 mWh
    10:09:19 Active AC 98 % 47,770 mWh
    10:44:29 Connected standby AC 98 % 47,720 mWh
    10:44:29 Suspended 98 % 47,720 mWh
    16:35:24 Active AC 98 % 47,620 mWh
    16:46:50 Connected standby AC 98 % 47,620 mWh
    16:47:22 Active AC 98 % 47,620 mWh
    16:57:26 Connected standby AC 98 % 47,620 mWh
    17:10:14 Active AC 98 % 47,620 mWh
    18:03:39 Connected standby AC 98 % 47,620 mWh
    18:06:35 Connected standby Battery 98 % 47,620 mWh
    18:06:40 Connected standby AC 98 % 47,620 mWh
    18:43:20 Connected standby Battery 98 % 47,620 mWh
    18:43:30 Connected standby AC 98 % 47,620 mWh
    18:56:23 Connected standby Battery 98 % 47,620 mWh
    18:56:28 Connected standby AC 98 % 47,620 mWh
    18:58:19 Active AC 98 % 47,620 mWh
    23:53:06 Active Battery 100 % 48,760 mWh
    23:53:53 Connected standby Battery 100 % 48,760 mWh
    23:57:03 Connected standby AC 100 % 48,760 mWh
    23:57:03 Active AC 100 % 48,760 mWh
    2019-08-1601:12:24 Connected standby AC 100 % 48,760 mWh
    01:14:30 Active AC 100 % 48,760 mWh
    01:15:06 Active Battery 100 % 48,760 mWh
    01:16:57 Connected standby Battery 100 % 48,760 mWh
    02:17:19 Active Battery 100 % 48,760 mWh
    02:17:41 Connected standby Battery 100 % 48,760 mWh
    02:17:41 Suspended 100 % 48,760 mWh
    09:36:52 Active AC 72 % 35,210 mWh
    13:13:53 Connected standby AC 100 % 48,680 mWh
    13:19:51 Active AC 100 % 48,680 mWh
    13:20:07 Connected standby AC 100 % 48,680 mWh
    13:24:58 Connected standby Battery 100 % 48,680 mWh
    14:35:52 Connected standby AC 100 % 48,680 mWh
    14:35:54 Active AC 100 % 48,680 mWh
    15:52:33 Connected standby AC 100 % 48,680 mWh
    18:56:14 Active AC 100 % 48,680 mWh
    20:24:49 Active Battery 98 % 47,860 mWh
    20:29:58 Connected standby Battery 98 % 47,860 mWh
    20:31:32 Active Battery 98 % 47,860 mWh
    20:32:04 Connected standby Battery 98 % 47,860 mWh
    20:32:06 Active Battery 98 % 47,860 mWh
    20:32:26 Connected standby Battery 98 % 47,860 mWh
    20:32:29 Active Battery 98 % 47,860 mWh
    20:32:37 Connected standby Battery 98 % 47,860 mWh
    20:32:56 Connected standby AC 98 % 47,860 mWh
    20:36:02 Active AC 98 % 47,860 mWh
    21:40:38 Connected standby AC 98 % 47,860 mWh
    2019-08-1700:07:53 Active AC 98 % 47,860 mWh
    00:39:11 Connected standby AC 98 % 47,860 mWh
    01:26:13 Active AC 98 % 47,860 mWh
    01:43:15 Connected standby AC 98 % 47,880 mWh
    01:43:15 Suspended 98 % 47,880 mWh
    10:07:21 Active AC 73 % 35,630 mWh
    11:00:00 Suspended 96 % 46,780 mWh
    11:01:05 Active AC 99 % 46,780 mWh
    11:07:33 Report generated AC 99 % 46,780 mWh
    2019-08-17T15:43:22+00:00
    SYSTEM PRODUCT NAME Microsoft Corporation Surface Laptop 2
    BIOS 137.2706.768 04/18/2019
    OS BUILD 17763.1.amd64fre.rs5_release.180914-1434
    PLATFORM ROLE Mobile
    CONNECTED STANDBY Supported
    REPORT TIME 2019-08-1711:07:33
