How to fix booting freeze on Surface Pro 9
Ben Weyer 5 Reputation points
2026-08-16T21:45:01.0333333+00:00
Please help!
As of one week ago, my surface pro nine was completely fine and working just like always as it has for two years. Like always there’s usually a routine update so I let my computer restart and let it update. During the update my screen froze and didn’t change for about 20 minutes so I thought it would be OK to just turn off my surface pro. After that my surface pro entered a booting loop where it would only show the Windows logo, then turn black repeatedly until it would enter the big locker recovery. From there, I would only have five seconds till the screen froze and I could do nothing. So I gave my surface pro to a friend who is very good at working with computers and is also working on a computer science degree. From there, he basically explained to me that my laptop is most likely dead in the water and there’s nothing else I can do. Which makes no sense because it was working fine as of one week ago. I’m an incoming masters student and I don’t exactly have the money to just go ahead and buy a new surface pro. Can someone please tell me anything I can do to fix this?
FYI, a lot of repair options just don’t work because of my laptop freezing in five seconds. I don’t have enough time to do a lot of things. This is been extremely frustrating and also nerve-racking due to my program starting soon and me not having a working computer.
Surface | Surface Pro | Performance and maintenance
1 answer
  1. S.Sengupta 33,171 Reputation points MVP Volunteer Moderator
    2026-08-17T00:17:03.99+00:00
    The fact that it freezes about 5 seconds after reaching BitLocker recovery is especially important because it limits the usual Windows repair options.
    With the Surface completely off:
    Hold Volume Up.
    While holding Volume Up, press and release Power.
    Keep holding Volume Up until the UEFI screen appears.
    If UEFI stays stable and doesn't freeze, that's encouraging. It suggests the basic hardware is functioning and the problem may be Windows/boot-related.
    If UEFI itself freezes, then I'd be considerably more concerned about a hardware problem.
    . If UEFI works, try a USB Windows recovery environment.
    Your BitLocker recovery screen means the drive is encrypted. You will probably need the 48-digit BitLocker recovery key to access the Windows installation/data.
    If you used a Microsoft account on the Surface, check Microsoft's BitLocker recovery-key page from another computer:
    Find your BitLocker recovery key
    A computer can appear "dead" while the SSD and your files are perfectly intact. The fact that BitLocker recovery appears is actually evidence that the machine is getting fairly far through the boot process.
