An Azure service that is used to develop microservices and orchestrate containers on Windows and Linux.
To enable the Fabric Data Agent to read the data from the Timepoint Interactive Detail table in the Fabric Capacity Metrics semantic model, ensure that the following prerequisites and configurations are met:
- Data Source Configuration: Verify that the Fabric Data Agent is correctly configured to include the Fabric Capacity Metrics semantic model as one of its data sources. You can add it by selecting the appropriate data source during the setup of the data agent.
- Permissions: Check that you have the necessary permissions to access the data within the semantic model. If permissions are restricted, the Data Agent may not be able to retrieve the data.
- Data Visibility: Ensure that the data in the Timepoint Interactive Detail table is not filtered out or restricted in any way within the semantic model. Sometimes, data visibility settings can prevent certain data from being accessed.
- Cross-geo Settings: Make sure that the cross-geo processing and storing settings are enabled in the Fabric data agent tenant settings, as these can affect data accessibility.
- Data Agent Instructions: Consider adding specific instructions to the Fabric Data Agent that guide it on how to handle queries related to the Timepoint Interactive Detail table. This can help improve its ability to retrieve relevant data.
If all configurations are correct and the issue persists, it may be beneficial to consult the documentation or support resources for further troubleshooting steps.
References:
