how to fix microsoftword power point and excell. it will not opoen it says run into trouble needs repair
Lyka Ayesha Leopoldo 0 Reputation points
2026-11-24T01:40:54.48+00:00
i cant open an app from microsoft especially word, powerpoint and excell it say run into trouble
Microsoft 365 and Office | Excel | For home | Windows
  1. AI answer
    2026-11-24T01:41:26.8933333+00:00
    Run Online Repair for Microsoft 365 or Office; it repairs the entire Office installation, including Word, Excel, and PowerPoint.
    Repair Microsoft 365 or Office
    1. Close all Office applications.
    2. Open the repair settings:
      • Windows 11: Right-click Start → Installed apps.
      • Windows 10: Right-click Start → Apps and Features.
    3. Find Microsoft 365 or Microsoft Office.
    4. Select the three dots beside it, if shown, and then select Modify.
    5. Select Online Repair → Repair.
      Choose Online Repair, not Quick Repair, because it performs the more complete repair.
    6. Follow the on-screen instructions and restart the computer when finished.
    7. Open Word, Excel, and PowerPoint to check that each starts normally.
    The repair applies to the entire Office suite even when only one application is selected.^1^
    If Online Repair does not fix it
    Completely uninstall and reinstall Office:
    1. Open Microsoft’s startup-error support page and run the uninstall troubleshooter.
    2. When prompted that the site wants to open Get Help, select Open.
    3. Complete the prompts and restart the computer.
    4. Reinstall the Office version associated with your Microsoft account.
    5. Open Word, Excel, and PowerPoint again.
    The uninstall troubleshooter requires Windows 10 or later and currently cannot uninstall Office 2024.^2^
    References
    1. Repair an Office application | Microsoft Support
    2. "Something went wrong" error when you try to start a Microsoft 365 app
  2. Ian-T 17,520 Reputation points Microsoft External Staff Moderator
    2026-11-24T06:11:48.2733333+00:00
    Hi @Lyka Ayesha Leopoldo
    I'm sorry you're having trouble opening Word, Excel, and PowerPoint.
    In addition to the repair steps mentioned above, you can try opening the applications in Safe Mode to check whether an add-in is causing the problem.
    1. Press Windows + R on your keyboard.
    2. Type winword /safe and press Enter to test Word.
    3. Repeat with excel /safe for Excel and powerpnt /safe for PowerPoint.
    4. If an application opens successfully, go to File > Options > Add-ins > Manage: COM Add-ins > Go, then temporarily disable the add-ins and restart the application normally.
    You can also refer to Microsoft's guide: Open Office apps in Safe Mode.
    If the applications still won't open, please share the exact error message or a screenshot so we can identify the issue more accurately.
