Surface pro 12 not sensing power cable
RDC 0 Reputation points
2026-11-16T13:23:05.62+00:00
I have a Surface pro 12 snapdragon that uses USB-C power. The unit stopped charging and I replaced the cable and power cube with a new 65W cube and cable. It now does has started to lose connection with the cube, but if I disconnect and reconnect the power icon turns green and says plugged in.
Is this a cue issue or a surface issue?
  1. S.Sengupta 33,271 Reputation points MVP Volunteer Moderator
    2026-11-17T14:26:47.33+00:00
    Try the other USB-C port. The Surface Pro 12 has two, and both can charge. If the other port holds a steady connection, the first one is physically worn or damaged. That’s a hardware fault and a warranty case.
    Check the port for debris. With the device shut down and unplugged, shine a light into the port. Lint packed in there is common and stops the plug from seating fully. Clean it gently with a wooden or plastic toothpick, never metal.
    Perform a forced restart: Hold the Power button for approximately 20 seconds, release it, wait a few seconds and restart.
    Check Windows and firmware updates: Ensure that the latest Surface firmware and USB-C controller updates are installed.
    Test with another 65W USB-C PD charger, preferably a Microsoft-approved charger. A 65W rating alone does not guarantee compatible PD voltage profiles.
  2. AI answer
    2026-11-16T13:23:20.77+00:00
    This points more to a charging-path problem than just the charger, because the new 65W USB-C charger and cable can briefly establish charging, but the connection drops and only returns after reconnecting.
    Start with these checks:
    1. Use a USB-C PD charger that provides at least the same wattage as the power supply designed for the Surface.
    2. Plug the charger directly into the Surface, not through a hub or dock.
    3. Use the cable that came with the charger or device, because not all USB-C cables support all features.
    4. Inspect and clean the USB-C port carefully. Dust or dirt in the port can prevent a stable connection.
    5. Restart the USB-C subsystem:
      • Unplug the USB-C charger.
      • Shut down the Surface: Start > Power > Shut down.
      • Wait 10 seconds.
      • Press and hold the Power button for about 20 seconds until the Windows logo appears, disappears, then appears again.
      • Plug the USB-C charger back in.
    6. Check for Surface driver and firmware updates in the Surface app under Help & support, then select Check for updates.
    How to interpret the result:
    • If another known-good USB-C PD charger and cable show the same disconnect/reconnect behavior, the issue is likely with the Surface USB-C charging port or internal charging hardware.
    • If a different charger and cable work normally, the issue is likely with the current charger or cable.
    • If the port feels loose, charging cuts in and out with slight movement, or the connector repeatedly drops even after cleaning and restart, that strongly suggests a Surface hardware issue rather than the power cube.
    For Windows USB-C charging issues in general, Microsoft also recommends using the included charger and cable when available, making sure the charger is connected to the actual USB-C charging port, avoiding external hubs or docks, and cleaning the port with compressed air.
