Problem making calls using Skype Dial Pad
Igor Skapinker 0 Reputation points
2026-11-29T03:24:22.1233333+00:00
I experience problem making calls using Skype Dial Pad in Teams. I have Skype credits and credits are active.
I get the following message when try to make a call
User's image
Please advise how to fix it.
Microsoft Teams | Microsoft Teams Free | Calls
  1. AI answer
    2026-11-29T03:24:37.5833333+00:00
    The message "Account is blocked" indicates the paid calling service is temporarily suspended. This can happen because of payment issues or because a billing address must be added before Skype Dial Pad can be used.
    Try these checks:
    1. Sign in to calling.web.skype.com with the same Skype account that holds the active Skype Credit.
    2. Verify that the correct account is being used and check the Balance area for active Skype Credit or subscriptions.
    3. Open My Account and review the billing details.
    4. If prompted, add or update the billing address.
    5. Try the call again from the Skype Dial Pad.
    6. Also check the Skype Status page for any current calling issues.
    If the problem continues, report it from Skype Dial Pad:
    1. Select the three dots in the upper-right corner.
    2. Select Settings.
    3. Select Help and Feedback.
    4. Select Report a problem.
    References:
  2. Ruwim.B 7,425 Reputation points Volunteer Moderator
    2026-11-29T07:09:34.01+00:00
    One of possible reasons for this error message might be that all Skype Dial Pad calls are now anonymous.
    Microsoft has recently disabled any Caller ID on Skype making all calls anonymous/private. If the called destination does not accept such calls, then this might result in a failed call.
