AUDIO PROBLEMS
Chiro Mabanta 0 Reputation points
2026-10-17T14:05:58.7733333+00:00
I cannot seem to find any solutions to my problems which is my mic, it is not readable and I always have to use my webcam as my microphone. Even when I have my Drivers UPDATED. PLEASE HELP.
Windows for home | Windows 11 | Devices and drivers
  1. Dio Xavier 297.7K Reputation points Volunteer Moderator
    2026-10-17T16:31:37.72+00:00
    Welcome to the Microsoft Windows Community.
    Good afternoon, @Chiro Mabanta . To help us provide a more accurate solution, please share the make and model of your computer, as well as a screenshot of your system specifications—you can do this by pressing Win+R, entering the command msinfo32, and hitting Enter. In the meantime:
    1. Check if your audio drivers are properly installed; is there sound working normally on your computer?
    2. Right-click the speaker icon -> Troubleshoot sound problems -> Input devices, and follow the on-screen instructions.
    3. Press Win+i -> Privacy & security -> Microphone -> Enable all permissions for your apps.
    Good luck, and see you soon!
  2. TaoLi 116.9K Reputation points Independent Advisor
    2026-10-17T15:05:47.6233333+00:00
    Hi, since your webcam microphone works, let’s check whether Windows detects the microphone you actually want to use.
    Open Settings >> System >> Sound >> Input. If your microphone appears, select it, open its properties, and click Start test while speaking.
    If it’s missing, go to Settings >> System >> Sound >> Advanced >> Troubleshoot common sound problems >> Input devices and run the troubleshooter.
    Is the microphone built into your computer, or connected through USB, Bluetooth, or a 3.5 mm headphone jack? Please share your computer model and a screenshot of the Input section.
  3. ApexNáV 390 Reputation points
    2026-10-17T14:52:59.54+00:00
    How this happens? Which PC or laptop you have?
  4. AI answer
    2026-10-17T14:06:59.6833333+00:00
    First check whether Windows 11 can see the microphone, then enable or select it; because updating the driver did not help, only reinstall the driver if the microphone remains completely undetected.
    1. Check whether the microphone is detected and selected
    1. Open Start → Settings → System → Sound.
    2. Under Input, look for the internal microphone, often named Microphone Array or Internal Microphone.
    3. If it appears:
      • Select it under Choose a device for speaking or recording.
      • Open its properties and select Start test.
      • Speak normally, select Stop test, and play the recorded sample.
      • Increase Input volume if necessary. ^1^
    If this test works, select the same microphone in the audio settings of the affected application instead of the webcam microphone.
    2. Enable microphone access
    Open Start → Settings → Privacy & security → Microphone, then turn on:
    • Microphone access
    • Let apps access your microphone
    • The switch for the application you want to use
    • Let desktop apps access your microphone for traditional desktop programs such as Teams or Zoom
    Desktop applications are controlled through the combined desktop-app switch rather than individual switches. ^2^
    3. Check for a hidden or disabled microphone
    Do this before removing any drivers:
    1. Right-click Start and open Device Manager.
    2. Select View → Show hidden devices.
    3. Expand both:
      • Audio inputs and outputs
      • Sound, video and game controllers
    4. Look for Microphone Array, Internal Microphone, or another microphone device.
    5. If it is greyed out or disabled, right-click it and select Enable device.
    6. If it has a yellow warning icon, open Properties and record the error code—such as Code 10 or Code 43—before making further changes. ^3^
    Also check for a physical microphone-mute key or privacy switch on the keyboard or laptop.
    4. If Windows still shows no microphone, reinstall the audio driver
    Updating a driver and reinstalling it are different operations. Reinstallation replaces a potentially incomplete or corrupted installation.
    1. In Device Manager, expand Sound, video and game controllers.
    2. Right-click the main audio device and select Uninstall device.
    3. If offered, select Attempt to remove the driver for this device, then choose Uninstall.
    4. Restart the computer. Windows should reinstall the audio device automatically.
    5. If it does not return, reopen Device Manager, right-click Sound, video and game controllers, and select Scan for hardware changes. ^1^
    Removing the audio device temporarily disables audio until Windows reinstalls it, so note the device name before uninstalling.
    5. Determine whether this is hardware-specific
    If the internal microphone is still absent:
    • Test an external USB or headset microphone.
    • If external microphones work but the internal microphone never appears in Device Manager, contact the PC manufacturer with the exact model and any recorded Device Manager error code.
    • If no microphone works, run Settings → System → Sound → Advanced → Troubleshoot common sound problems → Input devices. ^1^
    References
    1. Windows 11
    2. Windows 11
    3. My lenovo evo laptop does not recognise a microphone - Microsoft Q&A
