Surface Pro 3 Slow WiFi - 72Mbps Max (driver)
2014-06-21T05:48:07+00:00
I have an Apple Airport Extreme 802.11ac wireless router at home and am only connecting at a max of speed of 72Mbps (usually closer to 11Mbps if I'm more than 20 feet away from the WAP). I have two other 802.11ac laptops at home (Samsung AB9+ and rMBP) and my two other computers are connecting up at 800Mbps+ and pulling down the same on Internet speed tests; yes, I have real GigE connectivity. Is anyone else having these problems?
    2016-09-24T16:24:07+00:00
    Zach,
    We have a surface pro 4 , seems to have the same issue. Can you direct me to a link or instructions to increase dual band speed?
    Paul
  2. Deleted
    This answer has been deleted due to a violation of our Code of Conduct. The answer was manually reported or identified through automated detection before action was taken. Please refer to our Code of Conduct for more information.
    Comments have been turned off. Learn more
    2016-03-09T15:42:02+00:00
    For me the issue was the routers used channel!
    I had the exact same 144mbit/sec issue, fixed at that rate, or some 130.
    Now I checked my router and saw that on my used channel 6, much other WiFi routers were working. then i switched to channel 4, instant got 500mbit/sec on battery usage. So I did a sleep state, woke up the surface, still full 500+ mbit/sec
    So if anyone is still running into this issue, first update to latest drivers, then change your WiFi channel in the router.
    2015-12-09T20:56:59+00:00
    That fixed the problem, thank you! I downloaded the drivers from the link, installed, rebooted, and my speedtest jumped to 120mpbs. I incorrectly assumed that doing a Windows Update was giving me all the latest drivers.
  5. Barb Bowman 80,820 Reputation points MVP Volunteer Moderator
    2015-12-09T18:45:30+00:00
    Ah, with a custom Enterprise image on Surface, it is hard to say what "current" might be. the latest driver for Marvell, the new driver model ending in .47, was installed for folks with the regular retail image when they installed the update to TH2 1511.
    The drivers at https://www.microsoft.com/en-us/download/details.aspx?id=38826 are still from 10/26, i.e., the OLD drivers.
    You may need to open a support case to get these newer drivers if you've upgrade to 1511 and don't have the newest drivers.
