I also did this:
- Force-restart the Surface
This is different from a normal restart or Windows reset:
- Save your work and select Start → Power → Shut down.
- After it shuts down, hold the Power button continuously for 20 seconds.
- Keep holding even when the Surface logo first appears; release after the full 20 seconds.
- Start Windows and check Device Manager again.
Microsoft includes this forced restart in its battery-detection procedure.1
2. Manually reinstall the Surface Pro 8 firmware and drivers
Windows Update may report that everything is current even when reinstalling the model-specific package is useful after formatting Windows.
- Press Windows+R, enter
winver, and note the Windows build number. - Open Microsoft’s Surface Pro driver page and select the Surface Pro 8 download.2
- Download the
.msimatching your Windows build. For example, build 22621 uses a package whose filename begins withSurfacePro8_Win11_22621. - If there is no exact match, select the closest package with a build number lower than yours.
- Run the
.msi, complete installation, and restart. - Check:
- Device Manager → Batteries
powercfg /batteryreport- Settings → System → Power & battery
The package installs Surface Pro 8 firmware as well as its device drivers.
