IRQL not less or equal when changing volume of headphones
2024-11-04T11:12:42+00:00
Hello Microsoft, I am asking this question as I have a problem, whenever I connect headphones to my computer. I have both over-ear headsets I connect via "standard usb" and then "smaller headsets" I connect via "USB type C". I have Windows 11 with all the "latest updates" installed.
The problem happens when I change the volume of the headset/headphones in Windows. It happens randomly. I can change the volume 8 times where nothing happens, and then suddenly I change the volume the sound stops working, I have to disconnect and connect the headphones to get the sound to work again.
And now the problem has even extended itself. Now sometimes randomly when I change the volume of the headset/headphones, the sound will "buzzz" extremely loud, and after 5 seconds i get a blue screen with the message: "IRQL not less or equal". This ONLY happens when changing the volume of connected headphones to the pc, and I don't know what to do. I can listen to music for 5 hours, and then change the volume in a third-party software like Spotify or YouTube where "nothing" happens.
It only happens when changing the volume by using Windows.
Best Regards
Mathias T.
Windows til hjemmet | Windows 11 | Ydeevne og systemfejl
11 svar
Sortér efter: Meget nyttig
    2024-11-16T13:15:44+00:00
    It seems to work now, however i will avoid the Realtek drivers.
    I think the "Chipset drivers" did the thing.
    I also had another problem, when each time i unplugged the laptop from power, the sound would buzz and lagg a lot for 1 second, when switching to battery mode, and this is also gone now.
    Best Regards
    Mathias
