Mange flotte billeder i Edge - men hvor f... stammer de fra?
2020-10-28T13:58:22+00:00
Når man vælger en ny fane i Edge vises et billede som baggrund.
Det kunne være rart, hvis man kunne se hvor billederne er taget.
Microsoft Edge | Faner, adresselinje og søgning | Windows 10
14 svar
Sortér efter: Ældste
    2020-10-28T21:43:43+00:00
    Hey Dave
    OK
    Can you have someone at Microsoft look into the problem or must I just live with this missing feature?
    Are you not a Microsoft employee?
    Can I report the problem directly to Microsoft then?
    Best Regards, Kurt
  2. DaveM121 937.2K Omdømmepoint Uafhængig rådgiver
    2020-10-28T21:49:33+00:00
    Hi Kurt
    No, Community is just a user to user forum, I am just a user like you, the best option is to open Edge, then press Alt + Shift + i
    That will open the Feedback Panel in Edge, you can report this there and the Edge Developers will see that directly . . .
    2020-10-28T22:37:44+00:00
    Hey Dave
    Thank you - I will try that
    I can tell you that when I start Windows this also shows this kind of pictures and there it actually works like you describe
    Thank you for your help
    Best Regards, Kurt
  4. DaveM121 937.2K Omdømmepoint Uafhængig rådgiver
    2020-10-29T08:32:01+00:00
    Hej Kurt, glad to Help!
