Andre problemer eller funktioner relateret til Microsoft Edge på Windows 10
Denne browser understøttes ikke længere.
Opgrader til Microsoft Edge for at drage fordel af de nyeste funktioner, sikkerhedsopdateringer og teknisk support.
Hej,
Når jeg vil udskrive en web-side i Edge, vises udskriften godt nok, men der angives ingen sidenumre. Det kan derfor være lidt besværligt at udskrive udvalgte sider fra en omfattende web-side. På forskellige web-sider anføres, at man under udskriftindstillinger kan markere en option "sidehoved/-fod", men denne option findes ikke hos mig.
Mvh Jørgen
Hej Martmcd,
as suggested, i have disabled my extensions, but regrettable without success.
The curious thing is, that on my wife's userprofile (same PC) the option "header and foot" is available.
I have also tried to updating Edge from a fresh Microsoft download. But again with no better result.
Now i have used the Microsoft feedback option in Edge, hoping that they can help me.
When/if i hear something positive from them, i would gladly report the result to you.
But i also would like to, thanking you for your efforts helping me.
Best regards
worth sending feedback, it is used to make sure these things don't happen in future updates, if you gave your email address, you may get a response when a fix is available.
please do post the solution when you find one.
have you tried creating a new edge profile and seeing the problem remains.
click the ellipsis (...) and select settings
select profiles from the left panel and click Add profile (top right).
I am afraid I am running out of ideas, hopefully someone else knows a solution.
I will continue to look and if I do find a solution I will come back to you.
Hej Martmcd,
i'm a little stubborn, so this morning i decided to trying to solve the problem by changing all settings, one by one.
As i came to "margins", i changed the setting from "no margins" to f.ex. "standard" or "minimum" and suddenly the setting "header an foot" was visible and could be used.
So the problem is solved, but i think it's still a failure, that the setting isn't available when chosing "no margins"
Best regards
thanks for the update, I am glad you found a solution.
a little surprised though, in trying to replicate the issue, i reduced margins to nothing, the option remained but didn't work, the footer did not show. As I would expect.
you can make suggestions for improvements directly to the development team using the feedback hub (winkey+F)
I shall remember your solution if I see anybody else with the problem, Thank you.
