Bilješka
Pristup ovoj stranici zahtijeva provjeru vjerodostojnosti. Možete pokušati da se prijavite ili promijenite direktorije.
Pristup ovoj stranici zahtijeva provjeru vjerodostojnosti. Možete pokušati promijeniti direktorije.
This article explains the required index fields and configurations for agentic retrieval. None of these requirements are new. You can use an existing index that meets the criteria, even if it was created with an earlier API version.
Each indexed knowledge source depends on an underlying index. Depending on how you set up your pipeline, the index can be one of the following:
Existing: A standalone index that's exposed through a search index knowledge source. The index must meet the criteria in this article.
Generated: An index that's created automatically by an indexed knowledge source. Generated indexes meet all criteria by default.
Criteria for agentic retrieval
The following table organizes the index elements that affect agentic retrieval by requirement level.
| Index element | Requirement | Notes |
searchable and retrievable string fields |
Required | Used for query execution and result retrieval. |
| Semantic configuration | Required | Use defaultSemanticConfiguration or override the semantic configuration in the knowledge source. |
| Citation fields | Recommended | User-defined fields that attribute responses to source content, such as document name, page number, or chunk ID. |
| Vector fields and a vectorizer | Recommended | Enables text-to-vector conversion at query time. |
| Scoring profile | Optional | Boosts relevance for specific fields. Set defaultScoringProfile to apply automatically. |
| Analyzer | Optional | Controls how text is tokenized, such as handling whitespace or special characters. |
| Synonym maps | Optional | Expands queries with terminology or jargon. |
Example index definition
The following example shows an index that works for agentic retrieval. It meets the criteria for required elements and includes vector fields as a best practice.
A well-designed index for generative AI or retrieval-augmented generation (RAG) has the following components:
A description that an LLM or agent can use to determine whether an index should be used or skipped.
Chunks of human-readable text that you can pass as input tokens to an LLM for answer formulation.
A semantic ranker configuration because agentic retrieval uses level 2 (L2) semantic ranking to identify the most relevant chunks.
(Optional) Vector-equivalent versions of the human-readable chunks of text for complementary vector search.
Chunked text is important because LLMs consume and emit tokenized strings of human-readable plain text content. For this reason, you want searchable fields that provide plain text strings and are retrievable in the response. In Azure AI Search, you can create chunked text by using built-in or third-party solutions.
A built-in assumption for chunked content is that the original source documents have large amounts of verbose content. If your source content is structured data, such as a product database, your index should forego chunking and instead include fields that map to the original data source, such as a product name, category, or description. Attribution of searchable and retrievable also applies to structured data. searchable makes the content in-scope for queries, and retrievable adds it to the search results (grounding data).
Vector content can be useful because it adds similarity search to information retrieval. At query time, when vector fields are present in the index, the agentic retrieval engine executes a vector query in parallel to the text query. Because vector queries look for similar content rather than matching words, a vector query can find a highly relevant result that a text query might miss. Adding vectors can enhance and improve the quality of your grounding data but aren't strictly required. Azure AI Search has a built-in approach for vectorization.
Vector fields are used only for query execution on Azure AI Search. You don't need the vector in results because it isn't human or LLM readable. To minimize space requirements, we recommend setting retrievable and stored to false. For more information, see Optimize vector storage and processing.
If you use vectors, having a vectorizer defined in the vector search configuration is critical. It determines whether your vector field is used during query execution. The vectorizer encodes string subqueries into vectors at query time for similarity search over the vectors. The vectorizer must be the same embedding model used to create the vectors in the index.
By default, all searchable fields are included in query execution, and all retrievable fields are returned in results. You can choose which fields to use for each action in the search index knowledge source definition.
Add a description
An index description field is a user-defined string that you can use to provide guidance to LLMs and Model Context Protocol (MCP) servers when deciding to use a specific index for a query. This human-readable text is invaluable when a system must access several indexes and make a decision based on the description.
An index description is a schema update, and you can add it without having to rebuild the entire index.
String length is 4,000 characters maximum.
Content must be human-readable, in Unicode. Your use case should determine which language to use (for example, English or another language).
Add a semantic configuration
The index must have at least one semantic configuration. The semantic configuration must have:
- A named configuration.
- A
prioritizedContentFieldsset to at least one string field that is bothsearchableandretrievable.
There are two ways to specify a semantic configuration by name. If the index has defaultSemanticConfiguration set to a named configuration, retrieval uses it. Alternatively, you can specify the semantic configuration inside the search index knowledge source.
Within the configuration, prioritizedContentFields is required. Title and keywords are optional. For chunked content, you might not have either. However, if you add entity recognition or key phrase extraction, you might have some keywords associated with each chunk that can be useful in search scenarios, perhaps in a scoring profile.
The following example shows a semantic configuration that works for agentic retrieval.
The response provides title, terms, and content, which map to the prioritized fields in this configuration.
Add a vectorizer
If your index contains vector fields, the query plan includes these fields if they're searchable and have a vectorizer assignment.
A vectorizer specifies an embedding model that provides text-to-vector conversions at query time. It must point to the same embedding model used to encode the vector content in your index. You can use any embedding model supported by Azure AI Search. You specify vectorizers on vector fields by way of a vector profile.
The vector field definition in the index example shows the key field attributes: dimensions, which is the number of embeddings generated by the model, and vectorSearchProfile.
Vector profiles are configurations of vectorizers, algorithms, and compression techniques. Each vector field can only use one profile, but your index can have many in case you want unique profiles for every vector field.
Querying vectors and calling a vectorizer adds latency to the overall request, but if you want similarity search, it might be worth the trade-off.
The following example shows a vectorizer that works for agentic retrieval as it appears in a vectorSearch configuration. There's nothing in the vectorizer definition that needs to be changed to work with agentic retrieval.
Add a scoring profile
Scoring profiles are criteria for relevance boosting. They're applied to non-vector fields (text and numbers) and are evaluated during query execution, although the precise behavior depends on the API version used to create the index.
A scoring profile is more likely to add value to your solution if your index is based on structured data. Structured data is indexed into multiple discrete fields, which means your scoring profile can have criteria that target the content or characteristics of a specific field.
If you create the index using 2025-05-01-preview or later, the scoring profile executes last. If the index is created using an earlier API version, scoring profiles are evaluated before semantic reranking. The actual order of semantically ranked results is determined by the rankingOrder property in the index, which is either set to boostedRerankerScore (a scoring profile was applied) or rerankerScore (no scoring profile).
You can use any scoring profile that makes sense for your index. The following example shows a scoring profile that boosts the search score of a match if the match is found in a specific field. Fields are weighted by boosting multipliers. For example, if a match is found in the "Category" field, the boosted score is multiplied by 5.
Add an analyzer
Analyzers apply to text fields and can be language analyzers or custom analyzers that control tokenization in the index, such as preserving special characters or whitespace.
Analyzers are defined within a search index and assigned to fields. The fields collection example includes an analyzer reference on the text chunks. In this example, the default analyzer (standard Lucene) is replaced with a Microsoft language analyzer for the English language.
Add a synonym map
Synonym maps expand queries by adding synonyms for named terms. For example, you might have scientific or medical terms for common terms.
Synonym maps are defined as a top-level resource on a search index and assigned to fields. The fields collection example doesn't include a synonym map, but the following example shows how a synonym map with variant spellings of country/region names might be assigned to a hypothetical "locations" field.
Add your index to a knowledge source
If you have a standalone index that already exists and isn't generated by a knowledge source, create the following objects:
- A search index knowledge source to encapsulate your indexed content.
- A knowledge base that represents one or more knowledge sources and other instructions for agentic retrieval.
